1 - 18 of 18 Posts
SNERP!!!
Ddr? Ddr2?
What exactly are you looking for? You need to post the capacity you want and other details. The "best OCing ram" out there is kind of broad since there are about a kajillion variables.
Yes and very well when OCing
Set BIOS to DDR400 and that gives you the room for an easy 250MHz cpu bus.
If the CPU can go that high with the 11x default that is.
Go for it, we can get you OCing the 4200+ well with some DDR500 RAM!
404 Title Not Found
Originally Posted by accskyman
If you can wait for it, Gskill HZ ddr500 is awesome stuff. I'm hoping I have enough money to buy them next time I see any in stock. Most likely won't but I wish.
http://www.newegg.com/Product/Produc...82E16820231021
An email form G.Skill stated they are no longer making the DDR HZ series
They claim the ICs produced are not capable of meeting that standard.
Grab what good stuff you can. All the effort to make the good stuff is going twards DDR2!
I'd reccomend Corsair XMS 4400 Pro........its awesome. Got mine at 272mhz with 3-4-4-8 1T but I've had it at 265 3-3-2-5 1T
Discussion Starter #12
i just got 2g of Crucial Technology DDR500 and OCZ GXS 700w PSU.
it will ship it to my house in about 2-3day, I hope it help me OC my CPU some more.
my PC is set for now, just waiting for the G80 or R600 than i am done with it.
Is those ram Good for my Setup?
also the ram timing only 3-4-4-8, is that low or good? and if i set the ram as DDR400, the timing will go up right?
Discussion Starter #13
1more question, I got the http://www.newegg.com/Product/Produc...82E16820148018
Crucial Technology 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 500 (PC 4000) Dual Channel Kit Desktop Memory - Retail.
and wat is the different between my ram to :
http://www.newegg.com/Product/Produc...82E16820146578
Crucial Technology Ballistix 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 500 (PC 4000) Dual Channel Kit Desktop Memory - OEM.
is just 1 OEM and 1 retail? cuz the color r diff too? or mayb just the lighting? if they r differnet, which one is better?
i have dfi nf4 sli-d mobo i found some corsair xms 2x1gigs 400 pc3200 c2pt platinum series is this a good choice 230.00 i have 1gig patriot now
i'd say it's lighting
Hmm.. DDR500 sounds tempting but for now I think I will get my WC system set up and worry about more RAM. For some odd reason, its cheaper than DDR400 for me..
Originally Posted by biatchi
geil one s - if you can find them that is
I just ordered a set from Newegg! they got more in stock too. I was looking for the "ONE H" (I think its called) but i couldnt find any... Oh well I hope the S series will perform. Should give me what i need to get to 3.0Ghz on a 3000+
1 - 18 of 18 Posts
