I've been reading a lot that AMD systems really like tighter timings instead of faster clock speed for memory. However, some memory intensive apps do seem to perform better with the faster speeds despite bad timings.
I have pretty high-end, versatile RAM. What would be the optimal settings if my primary concerns are speed when running [email protected] or playing WoW? (programming and surfing the web are already sufficiently fast
As you can see from my sig rig, I can get the timings pretty tight if I try. I could also probably run this RAM at 2000MHz if I loosen them. Thoughts?
