best solution
248 Views 8 Replies 6 Participants Last post by  azcrazy
As u guys can see my HDD in my rig is gone ,but , i have a mobo that went sour too so i want to use that HDD,in the the HDD is the info of the other mobo, what u guys suggest i do, format, just put in there, other?
1 - 9 of 9 Posts
it should be fine, as long as the other mobo was also an intel chipset.
It probably wont work with out a fresh format, and if it does, it may not work properly (the windows boot, not the HDD)
I always start fresh, but you can try and put it in, should just give you an Error if it dosnt work. No Harm No Foul.
yea it was for my p5n-e, but i had nvidia driver in that HDD , an dim my sig rig i have no nvidia , u guys thing i may have a conflict on the drivers?
sorry for the double posting
if i reformat how i do it? can i plug it to another computer and reformat from there, if so , what program should i use ?
hey madd but i have no where to put it
And vista is not like XP that will reformat every time u do a fresh install
Plug the HDD into another system then run the vista disk it will give you the option to format
ok i tried plug and play , but , no luck , so i have to do a fresh install.
thank u guys
1 - 9 of 9 Posts
