1 - 20 of 37 Posts
What would be the best sound card for under $100 for pci express? This would be for gaming of course....
What is the difference is those 2 cards? Is it just the one for $150 has a casing on it?
Fatal1ty, copy pasted specs;
Audio Chipset X-Fi
Channels 7.1
Sample Rate 96KHz
Digital Audio 24-bit
SNR109dB
Realistic EAX 5.0 sound effects in games
Accurate 3D positional audio with X-Fi CMSS-3D
Hardware accelerated performance
Clearer voice chat
64MB of X-RAM
Connectivity
Dolby Digital Live
Cinematic surround sound from DVD movies
Xtreme Fidelity audio playback
Record your own music
X-Fi Titanium HD;
24 bit 96 kHz ADC - Play
24 bit 96 kHz 7.1 Channel DAC - Play
24 bit 192 kHz Stereo DAC - Play
24 bit 96 kHz Recording
Dont get the Fatality!
Its the same as a titanium just with a shield and extra ram, its just a waste of $.
For ~$100 get the Titanium.
If you can, get the Titanium HD.
Xonar cards are good as well but For gaming Creative is better, for music Asus work better, the best of both worlds Titanium HD
yeah creative is the best for gaming although they have bad drivers (not horrid though) in WIN7 but they are good
as said above the Fatal1ty is pointless , the same Titanium with useless 64XRAM
but for the Titanium HD that one is terrific for both gaming and music but it can only do 2 channels analoge , and yeah its more than 100$
so i think the best card in your case is the X-Fi Titanium
Some people have problems with the drivers for the x-fi Titanium in Win7 but havent heard anything like it of the Titanium HD
sorry mate i forget to mention this point
the Titanium HD is terrific for both Music Movies and YES it has stable drivers
and maybe to say something else about this card , it has swappable OP-AMPs so you have the ability to get even better performance form original OP-AMPs
sadly for the OP its more than 100$
Originally Posted by adridu59;14193673
Please consider Auzentech cards...
still they are above 100$ (the cheapest decent one is the Forte) ,although their drivers are stable, but they have a bad habit of dying after while of usage and Auzenech has the worst RMA service
Originally Posted by nathris;14191643
Stay away from Creative. Their driver support is horrid.
How so? I have never had a problem with their drivers. I've used the XtremeGamer, Fatal1ty Pro, and Titanium HD and have had no problems with it under Win XP 32bit, Win Vista 32bit, and Win 7 64bit. Most of the time the driver problems are due to the user.
X-Fi Titanium HD;
I wouldn't get the HD if it's mainly going to be used for gaming. The DAC on both cards are identical and the differences on the other components are mainly seen when listening to high fidelity music (which is what the card is targeted for).
The Pro has the shield and X-RAM (useless IMHO). The DAC on both cards are the same, so save your money and get regular Titanium.
The drivers for the HD were built from the ground up for W7 and Vista.
Earlier driver support had more to do with MS changing the sound drivers stack and totally dumping Creative's earlier work in favor of onboard.
Or so I hear...I guess I'll find out tomorrow when my HD shows up.
If you don't intend to use speakers, the fantastically priced Xonar DG would probably suffice. Amazingly enough, Asus released new drivers for the Xonar series a week or so back and the 3rd party unified drivers make it stronger than Creative's offerings in that respect, IMO.
1 - 20 of 37 Posts
