1 - 6 of 6 Posts
Well Basically I need a new soundcard, I just went out and bought some new headphones (AKG K81DJ's) and my onboard sound card has static and just is not pushing these hi-fi headphones enough, Im on a tight budget ATM, I dont need surround sound or anything, just something with a good crisp clear sound for music and headphone use. Thanks <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> <br />
<br />
<br />
Link to said headphones: <a href="http://www.headphone.com/products/headphones/all-headphones/akg-k-81-dj.php" target="_blank">http://www.headphone.com/products/he...kg-k-81-dj.php</a>
I got my Audigy2 ZS used off ebay for $40 shipped. Best deal so far. If you can find an audigy 4 for a tad more, its probably your best bet.
<tr>
<div>
Originally Posted by <strong>TheLegend</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1389561#post1389561" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I got my Audigy2 ZS used off ebay for $40 shipped. Best deal so far. If you can find an audigy 4 for a tad more, its probably your best bet.</div>
</td>
</tr>
</table>
</div><br />
Will look into,thanks.
Comb your local electronics shops for . . . just about anything. Nothing's worse than on-board sound, after all. The best performing budget cards available right now are the Creative SB Audigy SE and the Chaintech AV-710. Both are under $30 and infinitely better than on-board sound.
yeah, you don't need much to drive those cans, they're only 32Ohm if I recall.<br><br>
but they are a great selection! AKG k81dj's sound good, and are very sensitive to an EQ so you can get them to sound how you like. They are a little bass heavy, but give them time and they'll tighten up. I recabled mine and it helped as well.<br>
You also might want to consider using them as portable cans. they don't have a wide soundstage and thus are not good for gaming, but they make great portable cans (which is what I use mine for) they pair well with a PA2v2 headphone amp, or a PINT, PPAS or other higher priced amp, but for the money the PA2v2 or a PIMETA would probably be the way to go.
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>soloz2</strong>
<a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1390344#post1390344" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">yeah, you don't need much to drive those cans, they're only 32Ohm if I recall. <br />
<br />
but they are a great selection! AKG k81dj's sound good, and are very sensitive to an EQ so you can get them to sound how you like. They are a little bass heavy, but give them time and they'll tighten up. I recabled mine and it helped as well.<br />
You also might want to consider using them as portable cans. they don't have a wide soundstage and thus are not good for gaming, but they make great portable cans (which is what I use mine for) they pair well with a PA2v2 headphone amp, or a PINT, PPAS or other higher priced amp, but for the money the PA2v2 or a PIMETA would probably be the way to go.</div>
</td>
</tr>
</table>
</div>Soloz2,<br />
<br />
Ya I just don't want this fuzzy sound when there is silence. I'm def considering getting a portable amp, from what I hear they rock <img src="/images/smilies/cool.gif" border="0" alt="" title="Cool" class="inlineimg" /><br />
<br />
Mine are tight on my head and giving me a headache, they do that to you at first. And yea def. crazy bass. I like though. So much better than reg old headphones.<br />
<br />
DO you mean use amp for PC or for portable? And yes I got these mainly for music on my pc and Ipod also.
1 - 6 of 6 Posts
