Best tool to grind down alumnium in the back of my case?
369 Views 7 Replies 6 Participants Last post by  lohoutlaw
Ok, In the summer when I had watercooling, I cut a rectangle shaped cut out in the back of my case for my w/c pipes to run out to my rad, I used electrical wire to the keep the edges smooth, but now that I've sold my w/c for a while now, I would like to smother down the sharp edges from where I cut it out with plyers. Can anybody recommend a good tool to do this with?
1 - 8 of 8 Posts
Dremel or dremel like (knock off).
Dremel.
*COUGH* Dremel, Sanding wheel and/or grinding stone *COUGH*
Also, is there anyway to buff scratches out of alumnium, like in the bottem of my case?
The tool mentioned above (dremel of course), but if that is too much cash a simple fine file will do well.
Well I think my dad has a nice dremel I can use, I'm not sure about what attachments though.
Well i used a hole say ((1")) to cut mine and used 2 valve cover grommets to insulate my hose going thru case.
Another thought! Try using some universal door edge gaurds
1 - 8 of 8 Posts
