1 - 3 of 3 Posts
The very best you can do is make it yourself. A DD waterblock, and maybe a GPU block, a single or double heatercore (can pick up at NAPA or autoparts store, for single go 87 chevette), a good pump like a mag drive 5, some 1/2" tubing , and 2-4 good 120mm fans. Maybe a res is you want one.
DD ddc pump 3/8 inch
TDX
clearflex-60 tubing and clamps
GPU block - maze-4 or swiftech
Double HC and some 120mm fans, shrouds
You will have a totl setup for that much dough.
1 - 3 of 3 Posts
