1 - 15 of 15 Posts
I recently finished setting up my first Linux file server, and I'd like to make a backup of all the tweaked settings by making a copy of the disk it's installed on. If the first disk ever breaks or an update messes something up, I'd like to be able to swap disks to get it working again immediately.
Can I just copy/paste everything on the first disk to the 2nd disk?
If there is more to it, is there free software that will do it?
tbh I wouldn't bother with Clonezilla etc if you just want to back up one disk. Just run this as root from the command line:
dd if=/dev/sda of=/mount-point-for-disk-2/debian-backup.iso
You will need another storage device mounted (be it local, removable or internal storage) - but that would be the case however / whatever software you used.
(you can also cat /dev/sda > /mount-point-for-disk-2/debian-backup.iso if you prefer.
Small note, that would be an .img file, not an .iso
And yes, you can just copy+paste all the contents. The only thing that won't be preserved is the boot loader, which is easily restored.
Discussion Starter · #9 ·
Originally Posted by willis888 View Post
How would I restore a boot loader?
That would. You're taking a snapshot of the HDD and saving it as a file (like an ISO CD image, except this would be a HDD image)
"That" as in this?:
I'm a little confused because to me it looks like that command will create an image file. Then I would need to use some program to transfer that image onto a disk in a way that makes the disk bootable.
"That" as in this?:
As long as your boot loader is installed on /dev/sda (be it the MBA or inside a partition table) then the boot loader will be saved along with the file system contents.
Restoring it will be doing the same command in reverse: dd if=/image of=/dev/sda
Discussion Starter · #11 ·
Thanks for your patience and assistance. I don't have many bash commands memorized yet, and the manual for 'dd' was very helpful.
Would this:
ignore blank space on the drive and create a smaller .iso compared to 'dd'?
Would this:
That would do exactly the same as dd - in fact I personally use cat rather than dd myself.
Yeah you should backup, restore, and grow. This ONLY works if one disc is equal or larger than the other, and it has to be the disc your copying too. But backup, restore, than grow the filesystem to fill the new drive. Restart, welcome to your same old system!
Discussion Starter · #14 ·
Thanks mushroomboy. I wonder if backup and restore mean what I think they mean, and I can't even guess at what 'grow' means.
Backup: make an image file of a 500gb HDD that Linux is installed on, saving that image on a 2TB drive
Restore: output that file onto a 640GB HDD that I want to have around as a backup
Grow, or make the file system fill up the entire drive. It's a term some people use. =P I think it even has it's own command, not sure. Yeah, it does! lol It's typically used for iso stuff but anyways. When you DD the drive, you make an exact image sector for sector. The problem is you might migrate to a larger drive. In that case, you just DD the image back to the large drive then use a program to expand (grow) the file system to the entire drive.
[edit] My advice would be to DD the old drive partition (sda1 or similar) to the new drive directly, don't make an image. Do the whole drive and DD it to the new drive.
Reactions: willis888
1 - 15 of 15 Posts
