1 - 12 of 12 Posts
or Furmark
i dont knwo about OCCT but Furmark won't
if you look @ temps
btw if u dont want to watch temp
uhmm use the MSI afterburner stabilty test program, MSI kombustor same as furmark but will autmatically exit when get too hot, and there will be in the top right corner your GPU chip turning from gray(cool) to red(hot).
so if u think it is still too hot for me and dont want to risk it, you can exit
also, the chip is good till 100C its amde for that the GF100 Chip
Originally Posted by SadSoul
can this test bust my card up permanently?
And how long should I run it??
Thanks.
OCCT Will stress it alot, much more than furmark, and kombuster
Just watch temps and you will be fine
Imo furmark and kombuster are crap, they take like 10 mins to find 1 artifact, and they dont even have error checker, so you have to sit their and watch for artifacts, and to top it off they hardly stress the card
Gl mate
Can u see artifacts in Furmark??
You have to sit their and watch it
OCCT has a artifact counter built in
yes i did :/
when i gone too far
OCCT is good Crap if you want to destroy your stuff :/ (yes i am talking offensive angel so do you)
no srsly i am scared of using OCCT, it can blow up thign rpetty easily
anyway a artifact counter ooh yeah..
like the comptuter can see some rare artifacts that won't count.
there can be artifacts that the coutner wont pickup.
furmark Kombuster is enough to stress for games,folding, like everything what you do.
Why go stressing it so much that it will never happen in normal use?? till you run OCCT again..
How long do I need to run it?????
I usually do 10 - 20mins
Some people do 60
Up to you
Originally Posted by runeazn
yes i did :/
when i gone too far
Calm down mate
I said imo, not talking offensive
And you can also turn around for a sec and miss a artifact in furmark
Also OCCt wont destroy your stuff, it will stress the card though,
And no, OCCT makes sure your card is 100 percent stable, i know a guy with a 470 who was kombuster stable, 750 core @ 0.950v
Got him to OCCT it and errors straight away, and since errors slow down the card, you want to make sure its 100 percent stable, especially for folding
I fold fine :/
1 - 12 of 12 Posts
