Status
Not open for further replies.
1 - 16 of 16 Posts
So heres the thing, I recently got a new PC, and I'm about to get a dual core for it, hopefully, but I want to clean off the thermal paste from the other processor (for storage, or reselling, no idea yet)
What's the best way to clean thermal paste off used processors?
I will also do this to my other CPU's that I don't use, and some of them are pretty old (up to 8 year for one of my intels)
So, best way to clean a processor of old thermal paste?
The processor I'm replacing is good, but I changed my mind and want a dual core now, the system is only about a month old though. (It's not too good, just a basic PC for gaming and file storage, specs in my signature)
This has been asked over and over again. The most common method is by using cotton swabs and isopropyl alcohol.
Originally Posted by EmerilLIVE View Post
I'm not a fan of cotton swabs, they tend to leave hairs everywhere.
Yeah, but you can clean those off afterwards. They can be extremely helpful if the TIM is a bit stubborn at coming off.
Yes, rubbing alcohol, as high % as possible. Nothing below 90%.
Cotton swabs don't leave hairs as far as I know...be sure to use plenty of alcohol so the thermal paste isn't sticking to the swab.
seriously..just a normal piece of tissue is fine..just wipe the stuff off until its clean...ive always done it like that.
Linty much. I strictly use coffee filters. The things are cheap enough.
I use alcohol wipes, the kind that you use on cuts and stuff. They are usually %100 and take everything off with no leftovers. BUT I ONLY USE THAT FOR CERAMIC COMPOUND. For Silver-based compounts I use Arctic clean and a coffee filter.
Originally Posted by onelivestarfish View Post
alright a final answer for you:
coffee filter
Isopropyl alcohol (90% or higher)
done.
Are you sensing a pattern?
Use anything you want to get the majority of the goop off;
You can wipe it off on the Cat if ya want to
Then finish up with a Coffee filter and High % Isopropyl.
For even better result, then proceed with the ArcticClean -You'll be surprised at how much more comes off what appears to be a "spotlessly clean" surface -that you just did with Iso- when you use ArcticClean.
If you use the Iso first - You save on the ArctiClean and one $5 set will last you ages.\\
Sorted
I always found brake cleaner to remove everything.
i use a sock, just turn it inside-out, and scrub away. if it's clean, it wont leave any hairs!
1 - 16 of 16 Posts
Status
