Hello folks,
At the expense of sounding like a total idiot. I'm having trouble figuring out how to connect four fans to the mother board. Yes, I said four.....how lame huh? lol
I have the Raven RV02...for now, but may switch back to the Fortress FT02. My dilemma is connecting the 180 fans to the mother board, and still keep the fan control intact (and wire maintenance.) I've considered splicing the wires in parallel, but am uncertain at this time if the motherboard can handle it. The manual states the CPU pin out can handle up to 2A, but doesn't express other pins tolerance.
I have the common pin out, CPU fan, Channel 1 & 2, and Power Fan. The outtake fan is a bit confusing as well as I am unsure whether this should be connected to the Channel 1 (4 pin) but rather not connect there since there will be a wire dangling down to the center of the board. All fan connections are 3 pin.
My mother board is the Asus P7P55D-E Pro.
I thank you in advance of any help!
Tony
Tony
