So The Graphics Card i bought is about 20mm too long to fit perfectly in my case so i will have to cut out a section of the top metal part of the HDD bay
a section about 20mm x 20mm x 120mm Can anyone recommend me the best way to cut out this corner of metal?
It will only mean i cannot use the top 1 out of 5 HDD bays which is fine because i will never have that many anyhow.
I was thinking of either drilling a small hole the section i have marked out in pencil and cutting the rest with a coping saw and sanding off the edges
I dont have a jigsaw, but i do have a dremel i dont know how neat it will be to use one of those though...
comments appreciated
