My case right now is a total mess however I'm looking to clean it up and make it look like one of those million dollar PC's which if you haven't seen should:
http://www.million-dollar-pc.com/
First off, this is my case:
Only difference is the side panel which you can see above, mine has a window.
First off I'm going to add some nice Nanoxia fans since they just define green, sex and awesome at the same time. God damn you Germans.
Next I want to light up my case, I currently own a set of blue cathodes but they're too long or the colour is never very good. I could get a 10" Green cathode but is it a nice green?
My options are:
The cathode: http://www.aquatuning.co.uk/product_...en---10cm.html
or
Green LED Strip: http://www.aquatuning.co.uk/product_...ion-cable.html
What would look best.
Once I upgrade my rig I'll get a nice watercooling loop with green tubing too.
My options are:
or
