Using spraybombs and tape and a light touch with razor knife will do.
Edit: More specifically imagine what you want the final product to be and go backwards "layer" at a time--you will see how background colors are the first thing applied and so on by moving backwards through the process in your mind's eye. Stencils are useful primarily for reproduction--for one of a kind graphics or effects I would use tape and cut it lightly with a razor blade--a light tough so as not mar th finish below the tape--peel away the part you want to make a different color and leave taped everything else--after all the layers are on several layers of clear will help melt the edges and give it a uniform appearance.
