Well, pretty easy, but I want to make sure I'm doing it correctly as I don't want to mess anything up. I have 2 HDD's in atm. both 500GB, I want to reformat the one with Windows on it and reinstall the OS because of a virus, I have all my important files off, and I would like a fresh start anyways. So... question is..what's the best way to reformating? Should I unplug my "non-OS" hdd first aswell?
Do I just use the "Reformat" option under the C Drive properties or can I pop in my Vista disc, and boot from disc to reformat? I'm not sure which way is the safest/easiest. Also NTFS correct? NOT Fat32.
Sorry for noob question, I'm sure it's asked a lot =(
