5700LE is 250/400
slightly better. using the coolbit, optimal is around 356/612
my optimal changes everytime i do the test...
whats the best for you guys ?
whats the mose resonables one then ? i mean OC for 5700LE?
There's no optimal overclock. All the cards overclock differently because the cores are not all made at the same time. Also manufacturers use different memory chips--mosfets--pcb-- and cooling, so that also affects how high your card will overclock.
1 - 8 of 8 Posts
