Better System Information in UserCP?
64 Views 1 Reply 2 Participants Last post by  IEATFISH
Might be hard to put into the system, but if it's possible it would be nice.
A simple checkbox system where you check the items you need, and then list them. This allows more customization for people with more than 1 GPU, HD, OS, or Optical Drive. If people have a less complex system they can just leave them unchecked.
Example:
<Checkbox> Hard Drive 1:
<Checkbox> Hard Drive 2:
<Checkbox> Hard Drive 3:
<Checkbox> Graphics Card 1:
<Checkbox> Graphics Card 2:
<Checkbox> Graphics Card 3:
<Checkbox> Operation System 1:
<Checkbox> Operation System 2:
<Checkbox> Operation System 3:
<Checkbox> Optical Drive 1:
<Checkbox> Optical Drive 2:
<Checkbox> Optical Drive 3:
For example, I would do this:
<CHECKED> Hard Drive 1: 2x 80GB Intel x25-M (Raid 0)
<CHECKED> Hard Drive 2: 1TB Western Digital Caviar Black
<UNCHECKED> Hard Drive 3:
<CHECKED> Graphics Card 1: Primary: Sapphire Radeon HD 5970 OC
<CHECKED> Graphics Card 2: PhysX: eVGA 8800GT
<UNCHECKED> Graphics Card 3:
<CHECKED> Operation System 1: Windows 7 Ultimate x64
<UNCHECKED> Operation System 2:
<UNCHECKED> Operation System 3:
<CHECKED> Optical Drive 1: Asus DRW-2014L1T
<UNCHECKED> Optical Drive 2:
<UNCHECKED> Optical Drive 3:
1 - 2 of 2 Posts
I like this idea. I don't even know if the check boxes are needed, though, since the current system omits any space without information.
1 - 2 of 2 Posts
