1 - 1 of 1 Posts
Beyerdynamic Custom One Pro Black
Description:
Custom One Pro is just the beginning of a complete new product family from beyerdynamic "Custom Series". The first truly customizable and interactive headphone in the world. The end user can change the sound, the style and the application any time after the purchase. Custom One Pro is the first model in the series for 2012. Designed and crafted in Germany by beyerdynamic for Pro Users, Consumers and Prosumers. Use with portable and professional devices. One headphone many applications. Change the sound, the style and the look. The CUSTOM series is one-of-a-kind, as it allows you to redesign and re-engineer your headphones at any time, making them the perfect match for whatever the situation or your mood demands. This is truly a product for the new headphone 2.0 generation.
Details:
DetailValue
BindingElectronics
Brandbeyerdynamic
EAN4010118709029
FeatureCustom Sound Slider to change the sound anytime (closed, semi open, open design)
Customizable Style: easily change color of the headband, ear pads, ear cups plates design, detachable cable... Crazy or Cool ? Style and look!
New Velocity Drivers at 16 ohm, suitable for smart phone, ipad, tablets, home audio or pro audio devices
Variable Noise Reduction, adjust the Sound Slider for deeper bass and block out noises, or adjust to hear just a little ouside sound, you design it!
Quality. Made in Germany. Two year warranty by beyerdynamic USA
LabelBeyerdynamic
ManufacturerBeyerdynamic
ModelCustom One Pro
MPNCustom One Pro
PublisherBeyerdynamic
SKU270678
StudioBeyerdynamic
TitleBeyerdynamic Custom One Pro Black
Warranty2 years parts and labo
ColorBlack
CatalogNumberList - CatalogNumberListElement709026
Item Height5 inches
Item Length10 inches
Item Width6 inches
Package Height5.04 inches
Package Length8.98 inches
Package Weight1.28 pounds
Package Width7.56 inches
PackageQuantity1
PartNumberCustom One Pro
ProductGroupCE
ProductTypeNameHEADPHONES
Item Weight0.8 pounds
1 - 1 of 1 Posts
