1 - 20 of 44 Posts
Auugghhh. Well, I haven't played bf2 for ages (but got the most recent patch) and I can load up bf2 but can't join any servers, it just crashs straight to desktop.
What can I do?!?
EDIT:
Well, I just got 2142 and have exactly the same problem.
AUUUGGGHHHH
Disable VOIP, the latest patch screwd that up somehow.
I would get constant CTD with that option on in the sound settings...........turned it off and now no CTD
One other thing, have you changed you desktop resolution or refresh rate since the last time you played? This also causes CTD's
try turning off "VoIP" in audio settings that has worked for some people
other than that reinstall the game + full patch(worked for me)
EDIT : joe
lol
sorry mate
Other than that, make sure you haven't changed the resolution in the config files to something unsupported. If you have no idea what I'm talking about, then it's not the problem - But it's usually my problem when it's crashed =)
~Kahuna
Discussion Starter #6
When I click on audio that makes it ctd aswell.
lol reinstall the game
i know its a pain, i've reinstalled BF2 over 20 times attempting to fix crappy bugs like this
yep, reinstall. BF2 probably corrupts? itself if you don't play it for while!
And use the full patch
Discussion Starter #9
Reinstalling now
Ill let you know if it works.
May the Battleforce be with you
I'm in a weird mood today
Discussion Starter #15
Thanks.
Downloading 1.4 full now....*yawns*
Discussion Starter #16
Originally Posted by bdattilo
Since I see you fold, maybe [email protected] is causing the CTD. It makes stuff do that occasionally.
Thats only the graphical console that does that, I am using the...urm...other one.
i need to reinstall to see if it resolves some graphical issues im having but really cba doing it
Discussion Starter #18
AUUUGGGGHHHHH.
Finished reinstalling and repatching and I click on audio and it crash's!!
What can I do?
delete the Battlefield 2 folder from "My Document"
then go into game and click Audio, see what happens
BEFORE you do this make sure you know ur account password because you will need to "Retrive Account" when u go to sign in
1 - 20 of 44 Posts
