1 - 2 of 2 Posts
when Im playing BF2 multi, I keep getting kicked off within 2minutes with the message: "You have been kicked via Punkbuster (for 0 minutes). RESTRICTION: Corrrupted File/Memory (81159)" Anyone know what this means?
Eazy dude.....<br />
<br />
Have you tried manually updating punkbuster??? 2142 players are having a similar problem '<b><i>You Have Been Kicked Via Punkbuster For Excessive Teamkilling Or As The Result Of A Successful Kick Vote</i></b>' Which has been tracked down to a punkbuster error and so everyone has been asked to manually update punkbuster.<br />
<br />
If this doesn't fix it then try CCleaner Pro (Crap Cleaner usually works for me when all else fails).<br />
<br />
Finally, if these don't work, <b>right click and cut your profiles Folder</b> from <b>C:\\Documents and Settings\\Tom and Franny\\My Documents\\Battlefield 2</b> and paste it on your desktop. Then uninstall and reinstall the game, getting rid of everything <b>except your settings</b>. When you have completed the re-install, cut the profiles folder back to where it should be, overwriting the new one that has been put in its place.<br />
<br />
Now try the game again.<br />
<br />
If these don't work then i am afraid that chances are.....its hardware <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /><br />
<br />
I used to have similar problems and found that one of my RAM modules had bad sectors....so i had to replace it.<br />
<br />
Hope this helps mate<br />
<br />
MaK <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Reactions: The Viper
1 - 2 of 2 Posts
