1 - 14 of 14 Posts
playing bf2 i get on 1280x1024 on completelt maxed out settings i rarely breach the 35 fps mark. BF2142 i have to run 1024x768 on med settings to stay above 30. whats wrong here? isnt bf2142 the same engine?<br><br>
thanks for any help
Its a moded engine with some architectural upgrades probaly<br>
Those upgrades may be taxing on your system
<div>Originally Posted by <strong>Lt.JD</strong></div>
<div style="font-style:italic;">Its a moded engine with some architectural upgrades probaly<br>
Those upgrades may be taxing on your system</div>
</td>
</tr></table></div>
<br>
have you played it?
Yes i have played the demo
Discussion Starter #5
<div style="font-style:italic;">Yes i have played the demo</div>
</td>
</tr></table></div>
<br>
well the bf2 engine is exactly the same along with the system requirements, so its basically a really big mod. Chipp for example has a 6800 vanilla and running the same settings as me and his is fine. In fact, bf2142 runs better on his rig than bf2. i should be able to play the game at the same settings as Bf2
Try a complete reinstall, defrag HD, etc. clean it up.<br><br>
Might even try a reformat. that always helps a windows system... even if you reformatted last week, <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
Discussion Starter #7
im gonna try installing older drivers.
I think your FPS is a bit low. Do you have the latest DirectX9c (October Edition) installed? I get around 45 on max settings with medium textures and 1186x864 something resolution.
Jake try the dhzeropoint 84.66's from guru3d. they worked great for me. With everything on high cept textures ( only 1gig of ram ) i get 60 to 75 fps 1280x1024
I get around 45 fps with 1280x1024 with AA2x and mostly High/some medium settings.
Discussion Starter #11
LOL then somethings somethings obviously wrong if people with 6800GS's can run the game on high....im gonna install the 84.XX's
Discussion Starter #13
ok its installed, starting the game now
Discussion Starter #14
high fps = 55<br>
average fps 45<br>
low fps = 25<br><br><br>
think i suceeded? i suppose so. i was getting a LITTLE better FPS on 1024X768 on med so i guess its an improvement. on my other rig in my sig runnign the 91.'s im having hte same problem and that dips down into the 20's so i think i've solved it.
1 - 14 of 14 Posts
