1 - 3 of 3 Posts
ok im running dual 8800gt's and im getting worst fps in sli than with a single card
single card im getting 30fps this at the start of the game
Sli im getting 25fps at the same place with full sli scaling
my cpu is at 3.21ghz
Any help is appreciated, im gonna see if i can get a pic to show you guys
EDIT: i forgot to add settings is at high at 1440x900 res
i just added 2x aa and 4xaf and i got 30fps instead using sli
im getting 79% on my mane gpu and 99% on the secondary gpu
im not getting a print screen
Try running GPUZ and make sure that it's using percentage of the other card. Also make sure you enabled SLI where it needs to be enabled.
usage is fine im on the 258.96
EDIT: im getting 65% usage now in the game
1 - 3 of 3 Posts
