1 - 10 of 10 Posts
hi i recently bought a bfg geforce oc 256mb (non gt) was wondering if i can overclock it any higher than the original speed it was clocked to by bfg, i am pretty much new to this overclocking stuff would be happy if somebody could walk me trough this confusing proccess.
i run on a p4 2.0ghz with 512mb of ram, i also heard that the video card could pushed to a 410 mhz clock speed
the most stable config on my CoD2 is 640x480 resolution. thanks in advance
Either use ATITool: http://www.softpedia.com/get/Tweak/V.../ATITool.shtml and then click "Find Max Core" and leave for around 30 mins and then "Find Max Memory" and leave for about the same time or d/l coolbits: http://downloads.guru3d.com/download.php?det=815 and then click "set optimal freq" in the Advanced Section of your Display properties and it will detect an overclocked value for your card.
thx for the reply but this is gonna sound stupid .. isnt atitool for ati cards only ?? if it's not u are more than welcome to ban me for mah n00biness
The link I've provided is for nvidia as well as ATI.
not to be annoying o great overlocker .. but is there any way i can flash the bios from a bfg geforce 6600 oc 256mb to a geforce 6600gt oc 128mbit .. and is that a wise choice ? thanx
Discussion Starter · #8 ·
ummm.. i am doin around 400mhz core and 270mhz memory .. and as soo as i up the mem i can start seeing little yellow dots on the atitool cube !! is that normal or should i keep goin
Those are artifacts, you should set the highest setting where you don't get any.
sounds like that cards sweet spot on the mem would probably be 265 ? also no you can flash it from what it is to anything else "ram size", but you are able to flash it to something else "gt". its kinda hard to find gt bioses that have 256mb, they are out there though, just keep looking
1 - 10 of 10 Posts
