BFG 7800 GTX 256mb drivers&settings
424 views 1 reply 2 participants last post by  t4ct1c47
#1 ·
what drivers should i use?
where do i get them?
what should be the setting on my card ex.....
Force mpmaps
conformant texture clamp
extension limit
trilinear optimization
gamma correct antialiasing
transparency antialiasing
triple buggering
negative LOD bias
#2 ·
It's normally best to use the latest official drivers which are currently the 81.98's. you can obtain these directly from Nvidia's homepage at www.nvidia.com
As for settings, I tend to leave them set to application controlled and simply change the settings in whatever game I'm playing. So with a 7800 GTX thats 1024x1280 and maximum.
