1 - 4 of 4 Posts
I have 2x BFG 9800GT OC 512Mb as seen in my sig below. My question it this. Will the BFG 9800GT OC 1gig card work with my same card w/only 512Mb. i.e. both cards would be identical except one would have twice as much ram. Would that cause any problems or do I have to match the amount of ram when Using the two in SLI mode?
Thank you,
N2G
Z-80 > i9
It would work, although the 1Gb would only use 512Mb.
Thank you,
So basically I would be waisting money on a card w/more ram to run side by side with a card with half the ram. OK so much for that idea
1 - 4 of 4 Posts
