I have the same vid cards... Try EVGA Precission it should work. Oh you may also want to remove the card and try to blow any dust/lint or any furballs that may be caught in the cooling fins above or around the GPU area.
When I use evga precission for folding I set my overclocks to 625/1728/999 and fans at 100%
Then I have to set the override so that fans will stay at 100% you will hear the fans trying to slow down but if you have precission set up right it will override this and keep the fans at 100%.
You may be able to downclock your GPU clock to 600 to reduce gpu heat. The shader clock is most important For [email protected]
Good Luck,
N2G
Good Luck,
N2G
