BFG GTX260 Serial number location?
2437 Views 4 Replies 4 Participants Last post by  Outcasst
Hi there, I'm trying to register my card however i'm having some trouble finding the card's serial number. Usually they are stuck onto the back of the PCB's, however the GT200 series are completely enclosed and I can't find a serial number of any kind. I have looked on the box and in any documentation and I can't seem to find it.
Any ideas?
1 - 5 of 5 Posts
its on a small sticker on the PCB cover towards the PCIe connector. thats where mine is.
Its on ablack sticker. examine each side of the card carefully. You will find it
If the card was purchased in the USA, it would be on a white sticker with black text. The sticker should say something like "BFG S/N" and will be located on the BOTTOM of the card (facing the motherboard when installed) next to the fan area.
Yeah, it was on the motherboard side. Found it now thanks guys. Registered so i get my free copy of vantage, far cry 2 and a BFG torch :_)
1 - 5 of 5 Posts
