Originally Posted by DeaDLocK CoolerCases.co.uk They have 1/2 UV tubing... Only two colours and I cant tell if they would be able to get it to you by tomorrow. I doubt it since when I looked at P+P it was only 19p which is not 1st Class. |
Originally Posted by 6600Gt1047 ya, i heard thats a great site. does newegg.com do international? |
Originally Posted by Evil XP2400 I dont like UV tubing for the water setup... The additive will glow alot more. I got some UV tubing for my setup and it glows, but not that much.... I was very disapointed. |
Originally Posted by adas123 yeah, the UV tubing doesnt glowq very much. i got the danger den UV and thought it would glow very nicely, and i put a UV light right up next to it in the dark and it barely glows. but 1 thing i found was to use the vantec really bright like white light stuff, because that makes the tubing light up nicely. but the best if u want UV would be to get clear tubing and put dye in there, that way itll glow for sure |
Originally Posted by Evil XP2400 Not trying to highjack... But do you have a link to this very bright white lights??? |
Originally Posted by muffin http://www.sunbeamtech.com/PRODUCTS/HAPER%20LIGHT.HTML |
Originally Posted by Evil XP2400 Thats bad ass. One of those lights is more intense than all this tubes I have in my pc... Then I could get rid of all this wires.. ![]() |
Originally Posted by xms They dont do a UV version do they?? |
Originally Posted by muffin http://www.sunbeamtech.com/PRODUCTS/LASER%20LED.HTML |
Originally Posted by Lando95 Just a friendly reminder guys: Reps are not to be used as an incentive, or as a way of garnering responses. No worries, just FYI, thanks ![]() |
