Any one seen/used one of these rads? Know how many 120's can fit on there? I read the article, and It seems like an inexpensive piece. I'm on a tight budget, so why not check it out.
Originally Posted by ShawnMcGrail Any one seen/used one of these rads? Know how many 120's can fit on there? I read the article, and It seems like an inexpensive piece. I'm on a tight budget, so why not check it out. |
Originally Posted by Evil XP2400 That looks like my honda civic radiator... If it's a car radiator is gonna be more than 100 dollars brand new... A 16" fan could be the best thing for that, not a bunch of 120mm fans.. And then you would need a hell of a pump because that will most likely put alot of resistance ![]() ![]() |
