ok im having a little problem with my temps. the room temp is 68-73* F and i have been using the intelburn and occt to run stability test and i have a few temp monitoring programs running and they are all saying the same thing i have it over clocked to 3.0ghz 230HTT and running stock volts on everything I have the AMD x2 5000+ black. And my temps are going to over 100*C when i put it under 100% load. I know when you over clock it gets hotter but with that cooler i wouldn’t think it would get that hot. I have lots of fans 2 in the front one on the side one on top and 2 in the back.. All are 120mm but top its like 200mm. Am i doing something wrong hear or what. I know the temps don’t read right but hopefully there not that far off.Any ideas?
