1 - 8 of 8 Posts
Hi i want to order a Thermaltake CL-P0114 Big Typhoon heatpipe CPU Cooler.
But im worried it wont fit on my mobo. As next to the cpu are two heatsinks.
I have little fans on them but they can easily be detached.
This is what it looks likes http://img.clubic.com/photo/0000014000145862.jpg
The hsf might rise above them but im not sure.
Thanks for the help
It looks like it might be close, mine pushes against a couple capacitors that are next to the CPU, but not badly, and since the fan on the heatsink pushes air towards the mobo, if you took those blower fans off I think those heatsinks would still function fine.
dude, where did you get it from? ive been looking for it for aaaggeeesss and havent been able to find one, especailly in the UK
ive got mine installed, here are a few pics i didnt have any problems with it touching or knocking anything either.
1 - 8 of 8 Posts
