big typhoon what vcore could i use ?? help
414 7
hey im thinking of updating my cooling and getting a big typhoon what sort of vcore could i use and still keep my temps under 50c i would prob use as5 with it, would i be able to use 1.7v ?? or higher ??
1 - 8 of 8 Posts
Keep in mind that regardless of temperatures, using higher voltage will shorten the lifespan of the cpu. The transistors aren't designed to switch on/off with that much voltage, so don't go overboard even if the temps are fine.
Each processor is different. But I Ran 1.74 V-core with my Typhoon. I had the IHS removed though.
I gave mine 1.85 and it only got up to 42* load. Wouldn't recommend that much as my proc is dying just a few months later.
I say don't go past 1.65.
Discussion Starter · #8 ·
im going to be getting the same board as you and a new psu as well do you think i could get as good a overclock as you ?? what vcore are u yousing to get 2.7??
1 - 8 of 8 Posts
