1 - 9 of 9 Posts
Where ever I plug in my hard drive, my asus p5wd2 detects it as a slave drive and this makes windows give me random STOP errors by the name of 0x00000f4
How do I configure my sata hard drive to make it recognized as a master instead of a slave. The first time I built this system it was a master but now I have no idea what happened.
if ur drive is a sata drive, then u need to install the sata controller files maybe they are corrupted also u need to make sure ur bios sees them correctly...do both and see what happens....
You have 2 raptors, are they setup in an array (raid) is your bios acknowledging the raid or not. Look at the mainboard manual and make sure your tapped in with your sata cables correctly. If your in raid use your factory raid manager to diagnose, Its on the asus cdrom. Let us have as much info as possible there are many members here that are very experienced with your motherboard and raid arrays if you are running raid? sorry coudn't be more help at this point?
I have 1 sata hard drive now, I forgot to update my profile in a while. It's a 160GB hard.
Anyway, I had this problem a month ago. Anyway I replaced the case and cooled my system better and for soem reason after some overclocking and rebuildign of my system the problem went away. Now the same problem is back again.
I got the drive to be detected master but the problem still happens. My drive is OEM. Should I get a new sata driver for my mobo. I remember trying to install the controller from my mobo disk a while ago but the interface said Windows XP Pro already has these files.
What port are you plugged into?
wait right there mate....first off i need to ask u have a SATA or sata2? and you are talking about onboard sata ports right? btw, did u reinstall windows since then and more importantly did u unplug the drive before this problem started?
Discussion Starter · #9 ·
Bios is set in sata2 mode (there is that and Ultra ATA). I have reinstalled windows at one point to try and fix this problem when it first appeared a long time ago.
About unplugging the drive, do you mean something such as unplugging the computer, dis-assembling and later assembling it again and booting up? If that then yes.
1 - 9 of 9 Posts
