Aghhh,
My first BIOS flash has not went well, someone really does not like me.
I used winflash; yes I should have known better and done it from a DOS boot disk, too bloody late now! DFI recomended using winflash if i had no floppy, so i did :S
Anyway, winflash said all was good, rebooted and nothing, no post, no mobo beeps....
So, with nothing else to do I reset the CMOS jumpers, took the battery out for a minute then turned the power on with the jumpers in Reset postion. Got a succesion of beeps, about a second apart. I then powered off, put the jumper in normal pos and then rebooted. Same thing is happening now a succession of longish (slightly longer than normal post beeps)
Am i completly ****ed?!?
If so does this mean i need to order a new BIOS chip from DFI?
Thanks
<edit> Sorry, I used this bios http://www.dfi.com.tw/Support/Downlo...FLAG=A&SITE=US
Thanks
