A very easy way to flash the eVGA 680i is to burn the bios file (usually a .bin file) onto a CD. Just the bin file. Nothing more. Then when the computer is booting up, hit ALT+F2 (if you time it right, just once, if not, then you will be hitting this combination repeatedly). And voila!! The bios has been thoroughly flashed.
Of course several things to remember:
1. Always load defaults before flashing (for the overclockers out there).
2. After flashing, power down the entire computer, including the power supply. I clear my CMOS as well, but I am not sure that you have to.
I hope this helps. It is the simplest way to flash that I have ever used and no need for a floppy.
