1 - 2 of 2 Posts
I was just looking through the bios for my ASRock 939 board and mainly everything under the advanced/cpu section was set to auto. So I changed the voltage and multiplier settings to manual to overclock it some but I can only set the voltage to a max of 1.050v? but on auto settings it runs at the normal 1.45v? Any help is appreciated..
Thanks
EDIT: sry, I got it figured out..you can scroll up the list to select higher voltages..lol:withstupi
· Premium Member
As my Sig quotes say
Good work figuring it out
1 - 2 of 2 Posts
