I have come across the following:
Thermal managment Thermal monitor 1 Item Help
limit CPUID MaxVal disabled Set limit CPUID MaxVal to 3
should be disabled for xp
Question; I am making the asumption this is supposed to control temp. If this is true, why is it disabled? If it has nothing to do with temp then what is it?
OS Select for DRAM>64mb select OS2 if running OS/2
Question; whats this?
AGP Apertur size 64mb
Q: this?
**on chip VGA setting**
On chip frame buffer size 8MB
Q: and this? both of these settings can be changed.
And finally, do I want to "Load Optimized Defaults"?
Q: this?
