BIOS is giving me problems
1052 1
heya....i got an issue with my bios...it's on an asus p4pe-xte and the cmos resets ussually after a longer rig inactivity ,it resets my cpu speed to 2000 though it's a 2,6 northy [both cpu and gpu r oc'ed]
thx
1 - 2 of 2 Posts
Put a new battery in it... You can take the battery from an old computer if you have one that you're not using, or you can go get one for a couple bucks at your local computer shop or Radio Shack.
There are a couple types of CMOS batteries but I'm pretty sure they're compatible. Still, take the old one with you when you go to get a new one.
1 - 2 of 2 Posts
