1 - 8 of 8 Posts
Ok my bios isnt recognizing the HD and CD Drive! i think it has to do with the jumpers! ok so should i put the HD as Primary and in the Blue IDE slot i n the mobo right? what about the CD drive put it as Secondary? so i need helping on where to connect the HD and CD-D in the mobo,how to make Bios recognize it and how to set up the jumpers and which ones to set to primary or secondary! <br />
<br />
<br />
P.S. I only have i CD-D and no Floppy
Take the jumpers off both drives. You shouldn't but heh. It defaults to cable select, I think.<br />
<br />
Either way, set them both to cable select. On different ribbons.
Discussion Starter #5
yeah its the Hard drive i had on my old computer! it has some stuff on it nothing imopartant so i can erase if i need to
Bod ***s rock
reformat see if that helps
1 - 8 of 8 Posts
