BIOS not saving settings
1637 Views 3 Replies 3 Participants Last post by  Dopamin3
I'm trying to raise my FSB from stock, since I just loaded defaults with my newly downloaded BIOS, but whenever I try to raise it, I reboot, and they are stock.
1 - 4 of 4 Posts
are you pressing F10 to save your settings?
maybe you are going to high for your board?
Even going up 10 FSB, I still get the same issue.
Flash to newest bios and clear your CMOS afterwards.
If the problem still exists, you should probably replace the battery on the motherboard.
edit: if you already have the newest bios, downgrade back to your old one or contact Asus if the replacement battery doesn't fix it.
1 - 4 of 4 Posts
