ok, i have a asus P5LD2 Deluxe motherboard.im running a P4 550 3.4ghz prescot cpu, with arctic silver 5 and a thermaltake blue orb 2, and yes i applied a small amout and the cpu cooler is on tight. my idle temp is 50c and load temp is 72c!!!!
im just wondering before i buy a thermaltake big typhoon to lower the temps, is it possable doing a bios update it might give more accuracte or lower temps?
what bios version should i get? and what way should i install the bios?:
asus afudos: updates the bios in dos mode on a bootable floppy disk
asus crash free bios 2: updates the bios using a bootable floppy disk when the bios fails or gets corrupted.
asus ez flash: updates the bios in dos mode useing floppy disk.
asus update: updates the bios in windows evironment.
If you have a P5LD2 Deluxe, can you tell me what bios you are useing, cpu you have, type of cooling and temps and how you would update the bios.
