1 - 7 of 7 Posts
Hello when i enter my bios menu on my computer it does not have the option to change the frequency like overclocking it is not a branded computer what should i do<br />
<br />
Ausu p2b f<br />
p3 500mhz<br />
<br />
My old computer
FSB??<br />
If its not there its not there...sorry!
Could you give us some more Info on you setup Please?<br />
<br />
You could try using <b>ClockGen</b> to overclock through Windows but it has not as many options as a decent Bios.<br />
<br />
If You bought the Computer from A company like Dell the Bios options may be hidden/disabled
Discussion Starter #6
what kind of details do ya want <br />
the computer was build<br />
intel p3 500MHZ<br />
asus p2b f<br />
award bios revision 1013<br />
<br />
and clock gen wont work<br />
and every time i try softfbs and i move the bar it goes back to normal<br />
Please Thanks
On a pc that old there may be jumpers/dip switches on the motherboard you have to move or switch to change the vcore and/or the fsb/cpu clock speed. If you dont see those on the board and there are no overclocking options in the bios and you cant use clock gen or other software based overclock your out of luck.
1 - 7 of 7 Posts
