1 - 5 of 5 Posts
Hello does anyone no where on the internet i con find a custom bios for my old dell i no it is dangerous but i dont care because it would be going in the garbage any way it is a dell dimension 8100 1.4ghz blablabla<br><br>
I tryed searching but could not find any but i heard about them
You cannot modify the bios's in dells, there is no way you are going to overclock it unless you use something like clockgen.
From what I know you can't find such a BIOS, but you can spend 20$ on a used mobo and replace the old one...
esupport.com will write custom bios for you for about $50 bucks. You can also download cpu-z and if your motherboard actually shows up as (example MSI 6714) you can try the bios for that but beware it may be a different revision or something and the bios will cause trouble. I know trying to find a bios from a manufactures website like dell, HP, or emachines can be almost impossible so you may not be able to reflash.<br />
<br />
BTW, there is nothing wrong with that computer to qualify it as landfill material. It would make a fine addition to my folding farm.
<tr>
<div>
Originally Posted by <strong>sleepy127</strong>
</div>
<div style="font-style:italic">BTW, there is nothing wrong woth that computer to qualify it as lanfill material. It would make a fine addition to my folding farm.</div>
</td>
</tr>
</table>
</div>Or you could give it to a charity. I know that many charities use donated PCs <br />
to do their accounts, admin etc on. Try not to dump old PCs if possible <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> .<br />
<br />
Your best bet is to pick up a used and working motherboard to replace the one you've got. You've almost certainly got a proprietary PSU though, so you may need to obtain a better one, especially if you intend to o/c. Even if you use software to o/c your hardware from your OS (with the board you've got), you may well have stability issues and depending on how well you o/c, you may need to upgrade your PSU anyway, as Dell tend to only provide what the existing hardware will need and not much more, with PSUs...<br />
<br />
Highly-Annoyed
1 - 5 of 5 Posts
