1 - 4 of 4 Posts
try disabling some of the devices you won't use. Like the Floppy Drive, On-Board Graphics, On-board LAN, etc.
Also disable the other SATA and/or IDE ports that are not in use, so the mobo won't have to search those ports on boot.
Originally Posted by iAMDaman View Post
How do i disable the on-board ATI graphics from the bios? and is my graphics card supposed to be on the top or bottom PCIE slot?
Bottom. My A2+ came with a dummy card you are supposed to put in the top one, and the bottom one is the 'master' slot
1 - 4 of 4 Posts
