Alright I ordered my biostar a880g+ mother board a few weeks ago also using sata hard drives also to fix a ide cable hard drive
after that i turned it off and left it returning it to its original computer after i came back to turn it on ....... it didn't turn on at all while pulling
of the lid or what ever .... i looked at the power supply. It was fine until I moved the 24 pin power cable and then it turn on and
then theled flickerd with the led's on the power button
then I thoght it was the motherbord but the cable had to be at a weird angle to have been turned on sooooooo..............
MY Qeustion is what shold i do should i just send the motherbord and the power supply or do somthing else to make sure
bad punctuation
PLEASE AWNSER if power supply or motherbord IS ABLE TO BE FIXED
bad punctuation
