Which Mobo maker (past or present) has the best\easiest BIOS to use?
  • ASUS
    Votes: 2 50.0%
  • ASROCK
    Votes: 1 25.0%
  • ABIT
    Votes: 0 0.0%
  • BIOSTAR
    Votes: 0 0.0%
  • DFI
    Votes: 0 0.0%
  • EVGA
    Votes: 0 0.0%
  • ECS
    Votes: 1 25.0%
  • GIGABYTE
    Votes: 0 0.0%
  • INTEL
    Votes: 0 0.0%
  • MSI
    Votes: 0 0.0%
  • ZOTAC
    Votes: 0 0.0%
  • FOXCONN
    Votes: 0 0.0%
  • XFX
    Votes: 0 0.0%
1 - 12 of 12 Posts
I just purchased a Biostar TA890GBX-HD and I can't for the life of me, figure out how to manually OC the thing. I have a x555 BE and I don't even see anywhere I can change the multiplier at all. The ASUS bios is well laid out, but this Biostar one is like Greek to me. Does anyone have a couple of clues to drop on me? Thx.
Discussion Starter · #6 ·
Originally Posted by Metalcrack View Post
http://www.overclock.net/t/748349/official-biostar-800-series-club/0_100
Go to the "t-Series" tab
Overclock Navigator to manual
Go to CPU FID/VID Control,
Custom P-States to Enabled......
LET IT RIP
Thanks mucho amigo:thumb: It's not bad but I do have one more question.Is there anyway to select either core 3 or 4 individually? I know my x555 has a bad 3rd core?
Originally Posted by dixson01974 View Post
Biostar is a pain to oc, because of the setting for voltages are in 2 places.
yeah I saw that. It seems like the setting in green is like the offset in ASUS, and the other is the normal steps.
Easy....
Advanced
CPU Config
Core Leveling (change to manual) -they start with Core0 not Core1 so........
-Core1=Core0
-Core2=Core1
-Core3=Core2 (DISABLE ME)
-Core4=Core3
Discussion Starter · #8 ·
Easy....
Advanced
CPU Config
-Core1=Core0
-Core2=Core1
-Core4=Core3
Ok. So the bios ain't that bad. She's runnin close to my ASUS M4A89TD-M Pro with the exception of the ram. The VRM's aren't sinked but I do have a 200mm side fan that should cool just about anything in front of it. Thanks again +1
Originally Posted by jsc1973 View Post
Biostar T-series boards are a little bit of a hassle to figure out, but once you do, the boards themselves are excellent overclockers. Just don't try it with a non T-series from Biostar.
Not that I will, but why not non T series? Cheaper parts used?
1 - 12 of 12 Posts
