1 - 9 of 9 Posts
Originally Posted by pixie View Post
the max outside diameter of those fittings is 3/4"...
That means they will fit fine? I know 3/4" tubing works on the FuZion with room zip-ties so that means there's a slightly more than 3/4" clearance around each hole.
i don't have the block, i just have those fittings. i'm sure it'll be a pain in the ass trying to tighten them down, though, since you can't freely spin the whole barb.
actually, you might want to look at these. same idea, only you can put whatever size barb you want on them, or another fitting.
Discussion Starter · #6 ·
Thanks, I'm just gonna order and hope
They will fit but do not thread a good distance into the top.
I would not use a 90 directly to a block. I was going to
but many people say not to use them directly on a block. Plus
the Fuzion v2 is already restrictive and you don't want to make
it even more restrictive.
I thought about it, and yes they fit.
LOL
1 - 9 of 9 Posts
