1 - 2 of 2 Posts
i was looking at feser 1 black... but i keep reading it doesn't look black in clear tubing...
i am looking for the blackest coolant available.. i doesn't need to be UV as i am not going to be using UV.
and no i do not wna to use black tubes..
so what is the best black coolant...
how is this stuff as it looks like black chalk almost...
http://www.jab-tech.com/Fluid-XP-Pha...T-pr-3669.html
which one is the darkest?
http://www.jab-tech.com/PrimoChill-I...e-pr-4168.html
http://www.jab-tech.com/D-Tek-PC-Ton...k-pr-4192.html
http://www.sidewindercomputers.com/feonef1coflu2.html
I heard that the feser 1 black coolant really does that and some people just added some black dye to it to make it more black.. But I dont have the links though, so I cant prove it to you(maybe just to give you an idea)
For your other Q's:
I think the Dtek PC tonic is the darkest.
Just on a side note( in case you care )
I think a distilled water/Pt nuke gives the best performance
=) I hope I helped
1 - 2 of 2 Posts
