Ok, I have 2 monitors I use all the time. I also have a projector hooked up to my PC, and I enable and disable it as needed. I just did a reinstall, and now for some reason whenever I enable my projector my desktop wallpaper goes away and is just a black background. If I change display properties where the screen flicks around a bit (eg. enable/disable SLI) I can see the background for a few seconds then it just goes black again. Restarting usually fixes this, but I don't want to restart just to get my wallpaper back. Adding a new image does nothing, nor does changing to the next image (I use DisplayFusion to manage my wallpapers). Any ideas on how to fix this?
Edit: Sorted itself out after several more tries. Thanks for the advice though!
