1 - 20 of 808 Posts
Fold on!
~~ Black 'n White ~~
Intro:
Welcome to the buildlog of Black 'n White.
After a period without much modding I decided to do a new casemod.
The first time I saw the Fractal Design Define R2 Black Pearl I really wanted to mod it!
And not like I did before, a few little mods, but this time I wanted more.
So here it is, enjoy this log and I love feedback
Plan:
I have a lot idea's but I wont tell them all.
There will be paint(maybe powdercoating), cutting and sleeving. I want to hide a lot, to create a clean look.
The main goal is to get almost everything black and white.
Here is a little picture about one of the plans I have:
Parts:
I'm not sure if I will have the same hardware at the time I finish this project,
but this is what I have at the moment.
Intel Core i7 2600k
Watercooling
Asrock p67 extreme6
Corsair Dominator GT 2133mhz ddr3 4gb
EVGA GTS450
OCZ VERTEX2 60GB SSD
Fractal Design Newton R2 800W
Fractal Design Silent fans
And some random stuff
Updates:
Update 1 Fans and the case.
Update 2 Tunnel and pancakes!
Update 3 MDPC sleeving!
Update 4 MNPC stuff, sleeving and some modding.
Update 5 Led's and more MDPC goodies.
Update 6 Sleeving!
Update 7 EVGA GTX460 SC.
Update 8 Modding the ram and showing some hardware.
Update 9 2 new fans, some cable's and the case!
Update 10 The new hardware came in!
Update 11 SSD and backplate
Update 12 The system up and running!
Update 13 SSD mounted.
Update 14 New fans, fancontroller and lights.
Update 15 Painting the fancontroller + mobo tray and cutting a few things.
Update 16 Installed the new CPU and GPU's
Update 17 GFX card painting part 1
Update 18 GFX card painting part 2
Update 19 Watercooling
Update 20 Random holes
Update 21 Finishing the holes in the door
Update 22 Some parts came in
Update 23 GTX580!
Fold on!
Update 1:
Updates:
1-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16
Okay, I have a lot of parts already.
I really like the black and white style from Fractal Design, so I have a few parts from them:
First of all the fans:
And the case:
In the box
Installed a few parts for the pictures
I really like these doors, pretty easy to clean the fan filters too!
I couldnt wait to remove a few things
So there it goes, the HDD bay. One of the things I dont need, though it doesnt look bad at all!
You can see the power led here. I removed the stock Blue one for a White one. (stolen from the stock Darkknight fan
This is it for today, keep an eye out for the next update
Subbed and really want to see more of that door mod
lAptOp jUnKie
That's going to be a sick door mod if worked out properly. Believe it or not, I have the same door panel idea with a Lian Li case I'm thinkin' about buying. Nice selection regarding the Overkill Ring grills
Looking forward to see it completed
Reactions: battlecryawesome
I.T. Specialist III
Nice case and cool project!
Fold on!
Thanks for subbing
Originally Posted by CrazyV View Post
Uh Oh, No not again another Kitchen table turned PC build shop!!! R.I.P to the Kitchen table... LOL
Nice looking build. Can't wait to see your door mod
Hehe, that kitchen table is only used to take a few pics, most of the time I work outside or on my room. And if I'm going to do something inside, I've got to protect the table (mom is standing behind me with the frying pan...xD)
Thanks
I'll do my best to work it out, I've got the time, and some idea's
Send me a PM if you started with your log, cant wait to see it!
Thanks, if you are looking for a silent, clean and cool case this one wont let you down! I used to be a coolermaster fan, and I'm still, but this "sin" wasnt bad at all
Subbed for the win
I can't wait to see what you do with my R2 lmao
Fold on!
Discussion Starter · #18 ·
Update 2
Updates:
A small update today.
I did some work on the tunnels to get idea's what would be the best way to mount this stuff.
I want it to be removable, but it has got to be pretty sturdy, so I can move it without a problem.
The first idea I had was using the stock fan mounting. The only problem is that its plastic.
So its not strong enough. I need a few metal parts for this build,
so I'll see if I can make something for this too.
A few pictures from the tunnel:
How it looks without the door, so just a simple tunnel with a fan at the end.
How it looks from the inside. (there will be a box around the tube/fan, so it wont look like this
And how it looks from a few feet away.
Here are a few pictures from the inside. I installed some hardware a few days ago to see what I need to do to the interior.
5.25" bays and the tunnel.
The awesome black 'n white fans
The PSU with the GTS250 above it. (and an other gtx275 above that)
And this is what I did this morning, making a lot of pancakes
My mom asked me to do this, and it was a long time ago, so why not!
Finished product:
Thanks for watching, and maybe I have an other update at the end of the day.
Originally Posted by FEAR. View Post
Subbed
Cant wait for more updates
Thanks, I hope I can do a lot on this case the next 2 weeks, so plenty of updates incoming
Originally Posted by spiderm0nkey View Post
Subbed for sure!
Thanks Spider, enjoy it
1 - 20 of 808 Posts
